MenuItem pointing to another Menu. Is this possible?
Answered Question
Jan 14th, 2008
I would like to send a complete XML object to a phone that will contain an initial menu where its menu items point to another menu where those menu items contain the URL back to the server.
Menu
|_ Menu Item
|_ Menu
|_ Menu Item w/ URL
|_ Menu Item ...
When the user selects the first menu item, I would like to display the next menu and list of menu items without having to go back to the server and having it send down again.
Is it possible to embed a CiscoIPPhoneMenu within a MenuItem so I only have to send the xml one time?
Thanks for any help.
Brian
Correct Answer by Mike-1985 about 9 years 6 months ago
Nope... that is not possible!
You can only send one type of XML object (CiscoIPPhoneImage / CiscoIPPhoneMenu / etc...) each time. So when a user selects a MenuItem the server sends back an other CiscoIPPhoneMenu object. This doesn't take that much time about 0.3sec
Overall Rating: 5 (1 ratings)
Correct Answer
Mike-1985 Tue, 01/15/2008 - 00:16
sullyb007 Tue, 01/15/2008 - 06:14
Thanks Mike, I was afraid that was going to be the answer.
It's really not a issue of time; the problem is that I'm going to be sending an initial menu from one program, and the response from the phone will be going to a different program. That wouldn't be a problem if the ever changing sub menus weren't involved. Time to rethink the architecture.
Thanks again,
Brian
