DISABLE EIGRP network advertisement
Answered Question
Jan 14th, 2008
I need some help here!!! I need to disable EIGRP network advertisement with out using "no router eigrp 1025"
Correct Answer by mounir.mohamed about 9 years 1 week ago
A lot of filtering methods can be used, but it's depending on your design and requirements
For example, you can filter all or partial inbound / outbound routes via distribute-list
Router (config-router)#distribute-list 10 in atm1/0
Pls rate helpful posts.
Best Regards,
Mounir Mohamed
Overall Rating: 5 (1 ratings)
Correct Answer
mounir.mohamed Mon, 01/14/2008 - 10:22
Best Regards,
Mounir Mohamed
