VLAN question
Jan 14th, 2008
is it possible to have a static ip address device connected to a vlan without the vlan ip address assigned. im trying to have all network traffic go to this particular device.
dabels Mon, 01/14/2008 - 12:11
it would be nice to know what type of device you are talking about. if you are using a switch running IOS then yes you can connect a device to a switchport in a vlan and not have the interface have a ip address assigned to it.
avionics Mon, 01/14/2008 - 13:17
the device that will be connected is a skyX gateway for tcp acceleration. how would i make all the traffic flow through this device. current config attached. the port is fa1/0 where the device resides. Is this possible to have all traffic be routed through fa1/0???
dabels Mon, 01/14/2008 - 13:42
so you are wanting all traffic coming in to this router from every interface to get routed to the accelerator? if that is correct do they not support something like wccp redirection to force the traffic there? otherwise you may want to have a default route from the route to point to the fa1/0 (this is not a clean way though I would not think).
avionics Mon, 01/14/2008 - 13:49
the router platform is a 2800 series and i am unsure if it supports the wccp feature. How would i make a default route to direct the traffic through the device? Or how would i configure wccp? what is the best method for what i am trying to do?
chris.cumbaa Mon, 01/14/2008 - 14:07
If you WANT to configure WCCP, here's a short primer: http://articles.techrepublic.com.com/5100-1035_11-6175637.html
I wouldn't think this would be necessary if you are just using the gateway as a web proxy. If you're running a Windows network, you could just push down a group policy with the proxy settings to all of your users. If you want absolutely all outbound traffic diverted to this gateway, then you could configure the default route to point to it:
ip route 0.0.0.0 0.0.0.0
avionics Mon, 01/14/2008 - 14:16
would i delete the ip classless from my config? what command could i use to diagnose that the traffic is flowing to the right port.
avionics Mon, 01/14/2008 - 15:14
chris.cumbaa Tue, 01/15/2008 - 07:20
If you are running only strict class A B or C networks, you shouldn't need ip classless on your router. If you are further subnetting any class A B or C networks, then you must use IP classless.
If the skyX gateway is between your outbound router interface and the internet then you know the traffic is going through it. If the skyX gateway is networked on the same subnet as the outbound router interface and your default gateway and the new default route has been configured, then all outbound traffic will flow to the skyX gateway.
avionics Tue, 01/15/2008 - 08:33
could you give me an example of how this config of the interfaces? i listed a config on the prior post. could you help on routing traffic to the fa1/0 port.
chris.cumbaa Tue, 01/15/2008 - 08:58
If all of fa1/1 - 8 are configured to switchport access vlan 1, then you would have to ip your "interface vlan 1" on your router to the same subnet as your hosts on the fa1/1 - 8 ports. Configure this IP address as the default gateway on your hosts. The default route that I gave you earlier will push all traffic destined for an IP network not known to your router's route table through to the skyx accelerator.
If you would like to use a different vlan than 1, just replace all instances of "vlan 1" with "vlan x". Another thing you could do is put the hosts and the skyx gateway device on the same subnet and vlan and use the gateway as your default gateway on your hosts. If you are still having problems, post your current config.
avionics Tue, 01/15/2008 - 09:55
here is the current config. the sxy x is fa1/0 where all traffic needs to go through.
interface FastEthernet0/0
description unsecured test configuration
no ip address
duplex auto
speed auto
bridge-group 50
interface FastEthernet0/1
no ip address
duplex auto
speed auto
bridge-group 50
interface FastEthernet1/0
description "ACCELERATOR"
switchport access vlan 100
interface FastEthernet1/1
description "DV2"
interface FastEthernet1/2
description "STAFF4"
interface FastEthernet1/3
description "STAFF2"
interface FastEthernet1/4
description "DV1"
interface FastEthernet1/5
description "STAFF3"
interface FastEthernet1/6
description "STAFF1"
interface FastEthernet1/7
description "CSOSTATION"
interface FastEthernet1/8
shutdown
interface FastEthernet1/9
shutdown
interface FastEthernet1/10
shutdown
interface FastEthernet1/11
shutdown
interface FastEthernet1/12
shutdown
interface FastEthernet1/13
shutdown
interface FastEthernet1/14
shutdown
interface FastEthernet1/15
shutdown
interface Vlan1
no ip address
bridge-group 50
interface Vlan100
ip address 10.10.11.1 255.255.255.0
interface BVI50
ip address 10.10.10.2 255.255.255.0
ip classless
ip http server
control-plane
bridge 50 protocol ieee
bridge 50 route ip
line con 0
password 5152
login
line aux 0
line vty 0 4
privilege level 15
password 5152
login
transport input telnet
line vty 5 15
password 5152
login
scheduler allocate 20000 1000
end
SIPRNet#
chris.cumbaa Tue, 01/15/2008 - 10:53
Throw one of your devices on vlan 100 and give it an IP address in that subnet. Set the gateway to your accelerator. Test the connection. I assume there is some way to view connections on the accelerator. If that works, create a user vlan. IP the vlan interface. Make that IP address the default gateway for your users. Place your user interfaces in the newly created user vlan. Enter in the default route in global config mode:
ip route 0.0.0.0 0.0.0.0 10.10.11.2
--Change the 10.10.11.2 to the ip address of your accelerator.
