Some clarification
Jan 14th, 2008
I am getting the following error on my ASA5510;
7103042 Ike Initiator unable to find policy: Inft outside, Src: 172.16.2.14, Dst: 172.16.3.100
7103042 Ike Initiator unable to find policy: Inft outside, Src: 172.16.2.15, Dst: 172.16.3.100
This occurs when I setup my remote access uses to use the 172.16.3.x network doesn't occur when I give them address space out of my inside network which is 172.16.2.x
JORGE RODRIGUEZ Mon, 01/14/2008 - 10:36
This means isakmp policy is not configured, if this is a L2L session configure isakmp policy as this is part of Ipsec Phase 1 negotiation, if this session does not stablish L2L will not happen.
[edit] I take above back.
see error log 713042
Error Message %PIX|ASA-3-713042: IKE Initiator unable to find policy: Intf
interface_number, Src: source_address, Dst: dest_address
Explanation This message indicates that the IPSec fast path processed a packet that triggered IKE, but IKE's policy lookup failed. This error could be timing related. The ACLs that triggered IKE might have been deleted before IKE processed the initiation request. This problem will most likely correct itself.
Explanation If the condition persists, check the L2L configuration, paying special attention to the ACLs associated
http://www.cisco.com/en/US/docs/security/asa/asa72/system/message/logmsgs.html
