uccx agents with two icd extension ?
Jan 14th, 2008
Hi all, i have the following scenario:
agent1 has to worked in CSQ_1 and CSQ_2 depending o the day of the week.
For achieve this, i have created two extension mobility profile, one for CSQ_1 and one for CSQ_2. To reduce login/password/extension remindings, i was thinking of using just one profile with 2 buttons, one for each CSQ. The problem is that an agent can only have one ICD extension...
Does the agent will be able to log into the CAD with this configuration ?
(He could select the good extension depending on the CSQ he has to worked when login...)
Thanks a lot for your advises !
Chris Deren Mon, 01/14/2008 - 18:23
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
No, becuse an agent can be identified with only one ICD extension and the other one will not be usable.
Your best solution is to use 2 EM profiles.
Chris
