from inside to inside in a pix515e
Jan 14th, 2008
hi all i'm experiencing problem in a pix515e
client on inside are natted with a pool of public addresses on outside interface and all works fine but if i try to access inside client with their public address fron another client in inside network with his different pubblic address doesn't work ... idem from dmz to inside ... otherwise from inside to dmz all works fine ... from outside i can access anything
is there any special command to make this ?
thank you
Overall Rating: 4.5 (2 ratings)
1cmerchant Mon, 01/14/2008 - 12:03
If I understand your question correctly, you want IP traffic to enter the Pix and then exit it using the same interface right? If so then the command 'same-security-traffic permit intra-interface' may solve your problem. This command permits communication in and out of the same interface, which is not enabled by default. The only caveat would be that the code must be at least at v7.0x as I don't believe this command existed in the v6.3(5) and previous code.
roberto.costantini Mon, 01/14/2008 - 12:25
thank for your response ...
i've tried
pixfirewall(config)# same-security-traffic permit ?
configure mode commands/options:
inter-interface Permit communication between different interfaces with the
same security level
intra-interface Permit communication between VPN peers connected to the same
interface
pixfirewall(config)# same-security-traffic permit in
pixfirewall(config)# same-security-traffic permit inte
pixfirewall(config)# same-security-traffic permit inter-interface
pixfirewall(config)# same-security-traffic permit intra
pixfirewall(config)# same-security-traffic permit intra-interface
but it doesn't work enough ! :(
davecisco Mon, 01/14/2008 - 14:17
Sorry this does not help your post, but I have the same issue.
Internal client trying to get to internal server via host name. The host name gets translated to the public address so it does not work. AHHHHH!
Anyone find any more on this?
Dave
davecisco Mon, 01/14/2008 - 15:15
So what I have figured out is this.
Using the same-security commands allows anyone on the same lan as the address that gets NAT'ed to get to the NAT'd address. Anyone not on that LAN cannot.
User A 10.7.7.20
Server 10.7.7.10=204.50.200.1=site.intweb.com
User B 10.6.6.20
User A can now get to http://site.intweb.com but user B cannot.
Anyone know what can be done here?
Dave
roberto.costantini Thu, 04/10/2008 - 22:02
hi all, i've upgraded the ios in my pix but i can't arrive to the public natted address from inside interface ...
i've set same-security-traffic permit intra-interface command.
some ideas ?
this is my ver
pixfirewall# show version
Cisco PIX Security Appliance Software Version 8.0(2)
Device Manager Version 6.0(2)
thank you
vanagon2tdi Mon, 04/21/2008 - 08:13
Is the public address that you are trying to get to from the inside the public address of the PIX? If so, this will not work.
Can you post a bit of your config?
Dave
vanagon2tdi Tue, 04/22/2008 - 06:55
Roberto,
Can you tell me, based on the config you uploaded, which address is try to access which address?
Cheers!
Dave
roberto.costantini Tue, 04/22/2008 - 10:30
if i try to ping 151.13.20.200 (static nat of 10.1.3.77) from himself i not receive response... if i ping from my house's dsl line i receive response and i can access service ...
if i try to ping another host (ex. 151.13.20.10 from 151.13.20.200 or from 151.13.20.200 try to ping 151.13.20.10 ) from inside network or from any network inside natted host (pool 151.13.20.50-151.13.20 250) doesn't work ...
i've found this
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807968c8.shtml
but i must nat all the ip of inside network not just only one or two
I'm having the same problem running 7.0(2) on a PIX 515e. I have a second routed network inside my LAN. The PIX inside interface is the default gateway for the network. When a device on the routed network - 192.168.1.x - tries to access servers on the LAN - 192.168.50.x, the PIX drops the packets. I see it in the logs.
I've tried the same-interface commands but no good. Anyone found anything yet?
pengfang Tue, 01/22/2008 - 19:47
Hi all,
Only PIX v7.2 or later supports "hairpinning" for unencrypted traffic,also you probably have to do NAT on the Inside interface. I just drew a diagram and wrote some code, but don't have PIX/ASA to test it, anybody could test the code,please post the result.
If it helps, please rate.
davecisco Wed, 01/23/2008 - 09:59
I have two PIX's running in fail over mode with the below config and I still cannot get the hair pinning to work.
Again this is what I am trying to accomplish:
User A 10.7.7.20
Server 10.7.7.27=204.50.200.51=site.intweb.com
User B 10.7.4.20
User A can now get to http://site.intweb.com but user B cannot. User B cannot even ping the public address 204.50.200.51?
PIX-01# sh ver
Cisco PIX Security Appliance Software Version 7.2(3)
interface Ethernet0
nameif Outside
security-level 0
ip address 204.50.200.250 255.255.255.248 standby 204.50.200.251
interface Ethernet1
nameif inside
security-level 100
ip address 4.0.4.4 255.255.255.0 standby 4.0.4.5
access-list 101 extended permit ip any host 204.50.200.51
static (inside,Outside) 204.50.200.51 10.7.7.27 netmask 255.255.255.255 dns
global (Outside) 10 interface
global (inside) 10 interface
nat (inside) 10 0.0.0.0 0.0.0.0
nat (inside) 30 10.7.4.0 255.255.255.0
route inside 10.7.4.0 255.255.255.252 4.0.4.1 1
Am I missing anything?
Dave
davecisco Wed, 01/23/2008 - 10:19
No difference if I take it off.
What debugs should I run to watch the NAT translation? Keep in mind this is a live system.
Dave
Being a production system, I wouldn't use debug unless it came to that, and then only out-of-hours.
You could set buffer logging to warn -
logging buffered warnings
and then use -
sho logg | inc "ip address of bad box"
to see entries for your specific box only.
I was able to see that my routed network wasn't getting nat'ed at one point because it was logging something about no translation available.
I also used this to see that it was eating the traffic going in.
If that doesn't give enough info set buffer logging to debug and use the same filtered search of the logs.
davecisco Wed, 01/23/2008 - 11:17
Ok so when I do the debug it shows the packets from 10.7.4.1 trying to get to 204.50.209.51, BUT when 10.7.4.1 tries to hit that address it actually goes out the firewall. It is being translated to 204.50.200.250 which is the public that all the others on our network use. If I put in this command:
nat (inside) 20 10.7.4.0 255.255.255.0
which means 10.7.4.1 will be translated to 204.50.200.27 the same as anyone on the 10.7.7.0 network or the same as the web server I am trying to get to (10.7.7.27) then it works.
So basically what we are saying here is that if you use the outside address of your FW as the PAT address for everyone, then you cannot do hairpinning.
Make sense? Comments?
Dave
pengfang Wed, 01/23/2008 - 11:42
Hi Dave,
This is a little bit interesting, so why user A can access Server,it should have same behavior with user B (only difference is source IP),right? when u saying
User A 10.7.7.20
User B 10.7.4.20
1. Did u put " global (inside) 10 interface " when user A can get to http://site.intweb.com ?
2. If not, that means firewall doesn't do NAT at Inside interface. Can you do the same debug for User A to see if it been PATted to 204.50.200.250 ?
davecisco Wed, 01/23/2008 - 11:56
Yeah sorry my response was a mouthful and hard to understand.
User A is setup to go out as 204.50.200.27
User B is setup to go out as 204.50.200.250 which is also the IP of the Outside interface.
global (Outside) 20 204.50.200.227 netmask 255.255.255.255
nat (inside) 20 10.7.7.0 255.255.255.0
With this config user B cannot get to http://site.intweb.com but A can. This is because he is not going out as the Outside interface of the PIX.
So if I add in this command:
then it works from the 10.7.4.0 LAN as his new public (nat) is 204.50.200.27
So I think the hairpinning will not work when you are nat'd to the IP of the Outside interface.
To answer question 2. the user A is translated to 204.50.200.27.
Dave
davecisco Wed, 01/23/2008 - 12:43
So I have confirmed that if the users are going out as the public IP of the Outside interface or the PIX then the same-security-traffic permit intra-interface or hair pinning will not work.
Once I changed all the users to go out with a different IP than the Outside interface everyone internal can access the web page.
Hope this helps someone else!
Dave
pengfang Wed, 01/23/2008 - 12:49
That is great, in this case , I think "global (inside) 10 interface" is not functioning, if you remove this code, you should get same result.
davecisco Wed, 01/23/2008 - 12:52
Yep removed that line as it is not doing anything.
Dave
