Translation Route to VRU failing
Jan 14th, 2008
  • Bronze, 100 points or more
Worked once after initial config and then stopped.
The only error I can find is
Translation route timeout for controller B0878PG2 (ID 5002), route QM878.TR1.1 (ID 5008).
What should I check?
yshraybman Mon, 01/14/2008 - 12:09
When I do call tracer, sometimes I get
No free routes to send call to translation route QM878.TR1 (ID 5694). All 1 in use.
and sometimes
No peripheral target available for route QM.TransRoute (ID 5006) with routing client GRARMCCM_0878 (ID 5005)
cvenour Mon, 01/14/2008 - 15:48
How many numbers are in your translation route pool?
C.
yshraybman Mon, 01/14/2008 - 16:57
Just one.
But that wasn't the issue, I think. The whole thing did not make sense, I went thru config countless times to the point it was making me sick.
So I bounced PG. This knocked CTI RP out of PG user. Associated CTI RP back with PG user and it started working.
Am I running into a bug??
ICM 7.0 with latest SR.
