01-14-2008 12:05 PM
Redundant SCM does not boot in a CSS11506
The boot file is as follows
!************************ BOOT CONFIG ************************
primary boot-file sg0810107s
primary boot-type boot-via-disk
passive primary boot-file sg0810107s
passive primary boot-type boot-via-disk
The following commands were entered to sync the ios, configs and boot file
passive sync boot-config
paasive sync startup-config
passive sync image
Is there anything else I need to configure to make it work or is there an issue with sg0810107s?
01-15-2008 04:30 AM
what do you mean the redundant scm does not boot ? It will only boot if the primary SCM fail.
Gilles.
01-17-2008 03:59 AM
Hi Giles,
We simulated a failure by removing the primary SCM in slot 1 and the CSS rebooted but the standby SCM did not boot. We had to reseat the PMCIA flash disk in the standby SCM to boot it properly
Pravin
01-17-2008 05:15 AM
so you're all set ?
Gilles.
01-20-2008 11:10 AM
Yes, thank you..
