WCS --> WLC "Device un reachable"
jsivulka Tue, 01/22/2008 - 08:19
Please update the following informations
'show run-config' from the WLC and 'show run' from Switch connected to WLC while specifying the ports of Switch that connect to WLC in 2 separate text files.
=> Show msglog after the problem happens.
=> Check if there is crashes file available (WLC GUI ->Management ->Controller Crash)
=> 'show port summary' from the WLC when such problem happens.
=> 'show ip int br' from Switch connected to the WLC when such problem happens.
=> 'show arp switch' form WLC when such problem happens.
=> 'show arp' from Switch when such problem happens
The following URL will help you:
