Sup32 equiv.
Jan 14th, 2008
We have a WS-X6K-SUP2-2GE with the Switch Fabric Module 2 WS-X6500-SFM2
. We are upgrading the switch and wondering Wwat is the replacement for this blade when using a SUP32? Nad could you point me to a link for more info....
Joseph W. Doherty Mon, 01/14/2008 - 12:37
For the combination of sup2 w/SFM, you'll want to look at the various sup720 modules. the sup32 is classic bus only (somewhat like a sup2 w/o SFM).
Jon Marshall Mon, 01/14/2008 - 12:45
No there isn't. As Joseph says the SUP32 can only support the 32Gbps classic shared bus. There is nothing you can add to make this otherwise.
The Sup720, which has an inbuilt SFM, is the supervisor you need to support fabric enabled modules.
Jon
