'show arp' shows VLAN interface and not physical?
Answered Question
Jan 14th, 2008
Hi everyone,
I was wondering how I can find out the actual physical interface a MAC is learned on instead of the VLAN interface.
For example, on my switch I have:
show arp
Internet 192.168.0.25 - 0018.bad3.cb41 ARPA Vlan2
Internet 172.16.1.25 0 0009.0f06.ff0c ARPA Vlan3
The VLAN interface doesn't tell me which physical port it came out of...
Is there a way to find that out?
Thanks in advance.
Ali
Correct Answer by Jon Marshall about 9 years 2 months ago
Ali
You need to look at the mac-address table eg.
DC-BBP-F00-DS2#sh arp | include 000e.7fb4.f819
Internet 10.231.199.43 3 000e.7fb4.f819 ARPA Vlan40
DC-BBP-F00-DS2#
DC-BBP-F00-DS2#sh mac-address-table address 000e.7fb4.f819
Legend: * - primary entry
age - seconds since last seen
n/a - not available
vlan mac address type learn age ports
Supervisor:
* 40 000e.7fb4.f819 dynamic Yes 10 Po1
As you can see the actual interface this mac-address was learned on is po1 which happens to be an etherchannel connection to another switch.
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Mon, 01/14/2008 - 13:07
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Ali
DC-BBP-F00-DS2#
n/a - not available
Supervisor:
Jon
Paolo Bevilacqua Mon, 01/14/2008 - 13:23
  • Hall of Fame,
    Founding Member
Let me put it in another way to add to Jon's great example:
Show arp will tell you which layer 3 interface has the address.
But the info you want is at layer 2, so you need a layer 2 command, show mac-address-table exactly.
amiralisetoudeh Mon, 01/14/2008 - 15:53
Thanks to both replied - very helpful in understanding the difference between the two commands.
