RME device config export
Answered Question
Jan 14th, 2008
Hi all,
apart from exporting a device's config to the default export directory (C:\CSCOpx\files\rme\dcma\configexport) how can I view a config with no hidden fields? e.g. operators require a full config to enable a rebuild. On-screen has password / SNMP strings hidden.
thanks,
marty.
Correct Answer by Joe Clarke about 9 years 5 months ago
Not like you see it in the shadow directory. However, by using Config Editor, you can bring up a configuration, and all of the credential fields will be hyperlinked. When you click on the link, you will get a popup that shows you the cleartext value of the credential.
Overall Rating: 5 (1 ratings)
Joe Clarke Mon, 01/14/2008 - 14:01
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The latest version of each device's configuration can be found unaltered in NMSROOT\files\rme\dcma\shadow. Files in this directory are indexed by device name.
martyyates Mon, 01/14/2008 - 14:03
Hi Joe - but is there a way for a remote operator with no server access to view a config online with no hidden fields? Seems not.
thanks,
Marty.
Correct Answer
Joe Clarke Mon, 01/14/2008 - 14:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
