PRI to Catalyst to an IOS T.38 GW question
Answered Question
Jan 14th, 2008
The PRI are on a catalyst 6608-T1. I was told that I need make the PRI terminated on the 6608 be forwarded (only fax calls) to the Router(T.38 GW) by connecting a MFT-T1 card(router GW) to the 6608-T1...
Simple diagram:
T1 PRI T1
PRI ---> 6608 <--- Router
Fax calls are forwarded to Router (T.38 GW)
I'd prefer to just move the T1 PRI lines directly to the router to avoid having to make the PRI on the catalyst and router communicate, but the customer insists on having the PRI on catalyst.
Is there documentation fitting this scenario? Im at a loss...
TIA,
-Fred
Overall Rating: 5 (1 ratings)
