The usage of 'caputre' command in ACE
Jan 14th, 2008
I have a question about the capture command.
I would like to capture the traffic through ACE. So I tried the capture traffic like below
#capture aaa all, but error.
the error message is 'the buffer not set'
the error message is not extractly but the same meaning.
How can I use the capture command?
Am I missed the configuration?
Overall Rating: 4 (1 ratings)
Roble Mumin Tue, 01/15/2008 - 02:19
Capture is used to sniff traffic flowing through the ace itself.
What you were probably looking for is the command "debug".
try -> debug aaa all
This will show you all AAA related traffic/events.
Be sure to remove the debug condition before logging out with "undebug all"
If you want to capture traffic you need an access-list.
conf t
access-list All permit ip any any
capture all access-list All bufsize 2048 circular-buffer
That should help you capture/sniff traffic passing through the ACE itself.
Capture and Debug are two different things. :)
Hope it helps
