CUE language question
Answered Question
Jan 14th, 2008
  • Bronze, 100 points or more
Hi dear forum, I have one question, If I install a Spanish language package in my AIM-CUE, it means that i could have another option for the AA script with the audio files but in spanish to handle calls I mean, for example: "if you know the number of the person...." but in spanish or I needed to record new audio prompt files.
Thanks and best regards
David
Correct Answer by Rob Huffman about 9 years 3 months ago
Hi David,
Hope things are going well for you (you seem very busy!)
Just to add to Paolo's good note. Here is some related info;
CUE - Adding or Removing Languages
Installing additional languages or removing languages must be done in online mode only. You cannot add or remove languages using the boot helper except when you perform a complete installation of the Cisco Unity Express software.
Installing Additional Languages
Prerequisites
The following information is required for installing languages:
URL of the FTP server.
Restrictions
You are limited to 2 concurrent languages with an AIM-CUE module license
You are limited to 5 concurrent languages with an NM-CUE, NM-CUE-EC, or NME-CUE module license
From this good doc (with Step by Step);
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_installation_guide_chapter09186a008087723b.html#wp1109793
Here is what you need;
To download a language file for voice-mail prompts, go to http://www.cisco.com/pcgi-bin/tablebuild.pl?topic=281001346.
Have a look at the method listed at this link that detals changing the CUE Language without losing all existing data;
Frequently Asked Questions
I have a working system and I want to change the language (while saving all the data on the system). Which procedure do I need to follow?
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_tech_note09186a008064172a.shtml#qa1
Hope this helps!
Rob
Correct Answer by paolo bevilacqua about 9 years 3 months ago
Hola, all the messages will come in language wanted, and you don;t have to record anything.
Overall Rating: 5 (2 ratings)
Correct Answer
paolo bevilacqua Tue, 01/15/2008 - 01:37
  • Hall of Fame,
    Founding Member
Correct Answer
Rob Huffman Tue, 01/15/2008 - 05:33
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi David,
Prerequisites
Restrictions
Hope this helps!
Rob
david-lima Wed, 01/16/2008 - 12:53
Hi Rob and "p.bevilacqua" and thanks, thanks for your helpful answer, people like you made this forum very helpful.
Best regard
David
Rob Huffman Wed, 01/16/2008 - 16:20
  • Hall of Fame,
    Founding Member
Hi David,
You are always welcome my friend! Thank you for your very kind words. It takes all the participants here to make this the great community it is. Please continue to ask and answer questions, this way we all learn together!
Welcome aboard :)
Rob
