vlan information
Jan 14th, 2008
Hi NetPro,
anyone know this
Unicast Entries
vlan mac address type protocols port
296 0000.0c07.ac60 dynamic ip GigabitEthernet1/2
296 0002.8a95.c5ab dynamic ip GigabitEthernet1/2
296 0002.8aaa.456e dynamic other FastEthernet2/2
296 000e.9b28.c8e6 dynamic ip GigabitEthernet1/2
296 000e.9b47.3e18 dynamic ip GigabitEthernet1/2
296 000e.9b47.3e1d dynamic ip,other GigabitEthernet1/2
296 000e.9b50.9d2b dynamic other FastEthernet2/2
296 000e.9b53.441c dynamic other FastEthernet2/3
296 000e.9b90.b4e9 dynamic ip,other FastEthernet2/3
296 000e.d6f4.cc00 dynamic ip GigabitEthernet1/2
296 000e.d6fd.fc00 dynamic ip GigabitEthernet1/2
296 000f.34df.999b dynamic other GigabitEthernet1/2
296 000f.34df.9b56 dynamic ip,other FastEthernet2/1
why there is Dynamic , IP .
Dynamic , Other.
IP.
Vlan 296 used for Wireless, thought all should be same pattern in Dynamic , ip.
thanks.
regards,
Jack
Overall Rating: 5 (1 ratings)
ankbhasi Tue, 01/15/2008 - 02:19
  • Cisco Employee,
Hi Jack,
If the end device whose mac address learned on some port does not use ip protocol then the protoccol displayed will be other. CATOS recognise only ip and ipx as a protocol and rest will be shown as other.
Dynamic means these mac address are learned dynamically when they come onto the network rather than static manual entries.
See if this link helps you
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.1/19ew/command/reference/show1.html#wp1024089
Ankur
*Pls rate all helpfull post
