andrew.burns Tue, 01/15/2008 - 01:35
  • Gold, 750 points or more
WCCP is available on all versions of 2800 software and is commonly used as a transparent redirection method. The other transparent method is to use a L4 switch (Cisco CSS or something like that).
Alternatively, you can do non-transparent redirection (otherwise known as direct proxy routing) - but which method works for you depends on your infrastructure.
HTH - please rate useful posts (not just mine!)
Andrew.
