difference between cisco 7206 and cisco 7206vxr router
Jan 14th, 2008
any one help me to explain difference between cisco 7206 and cisco 7206 vxr router.actually my customer ask me about this.
marikakis Mon, 01/14/2008 - 22:24
You can see the following information in the URL provided below:
"CISCO7206VXR has a faster backplane than the CISCO7206 (up to 1 GBPS versus 500 KBPS), and has integrated multi-service interchange (MIX) functionality."
"Cisco 7200VXR systems support all port adapters supported on the Cisco 7200, except for the ones listed in the Table 3. Alternative solutions for the port adapters are also explained in the table."
"For some port adapters, there is a minimum revision level for the hardware to enable the port adapter to operate in a Cisco 7200 VXR chassis."
http://www.cisco.com/en/US/products/hw/routers/ps341/ps348/index.html
Kind Regards,
M.
