TTL value in PING response
Jan 14th, 2008
Can someone explain to me in details on what basis the TTL value is displayed when we ping a remote host.
I am pinging a remote host from my WindowsXP system. Sometimes the TTL value is less than 127 and some times its close to 255. Both the resources are on internet.
Overall Rating: 5 (3 ratings)
shrikar.dange Mon, 01/14/2008 - 22:38
  • Bronze, 100 points or more
hi,
In my knowledge the TTL value is the number of hops the packet takes along the path till destination.The number of hops is equal to the number of L3 devices through which the packet has traversed.Each time the packet arrives @ L3 device it processes it and forwards with decreaseD TTL value.
The different numbers in your case may be because the packet must be travelling from different paths.
HTH,
regards,
shri :)
avilt Mon, 01/14/2008 - 23:08
I am pinging resource X which is 26 hops away and resource Y which is 16 hops away from my system.
C:\>ping x.x.x.x
Pinging x [x.x.x.x] with 32 bytes of data:
Reply from x.x.x.x: bytes=32 time=289ms TTL=236
C:\>ping y.y.y.y
Pinging y [y.y.y.y] with 32 bytes of data:
Reply from y.y.y.y: bytes=32 time=19ms TTL=112
On what basis the upper TTL value is taken? Why the TTL value is 236 when I ping X and TTL value is 112 in case of Y?
Jon Marshall Tue, 01/15/2008 - 00:13
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Is y a windows machine and x a non-windows machine ?
Windows machines use a TTL beginning at 127 whereas unix/cisco devices use a TTL starting at 255.
Jon
avilt Tue, 01/15/2008 - 00:28
My source machine is Windows XP, I do not know about X and Y.
Jon Marshall Tue, 01/15/2008 - 00:30
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Source machine doesn't really matter, it's what the destination machine uses as it's TTL when it generates the ICMP echo response.
Jon
Jon Marshall Tue, 01/15/2008 - 23:52
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Michael
Many thanks for that, nice to be appreciated :)
Jon
mohammedmahmoud Wed, 01/16/2008 - 05:27
  • Green, 3000 points or more
Hi Jon,
I just want to add to your very valuable information, as you said the TTL is all about the destination and has nothing to do with the source, different OS has different TTL (considered as an aspect of the OS fingerprinting):
Windows: 128
Linux: 64
Cisco: 255
Solaris: 255
below are ping results from the LAN to an example of all those from the same source:
Reply from 10.10.99.2: bytes=32 time<1ms TTL=128
Reply from 10.10.99.166: bytes=32 time<1ms TTL=64
Reply from 10.10.99.1: bytes=32 time=1ms TTL=255
Reply from 10.10.99.13: bytes=32 time=1ms TTL=255
BR,
Mohammed Mahmoud.
Jon Marshall Thu, 01/17/2008 - 02:36
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Mohammed
Good to see you back in action.
Jon
mohammedmahmoud Thu, 01/17/2008 - 02:52
Hi Jon,
I am very glade too. Hope you are fine. I've tried to reply on your email a couple of days ago, but i get "Delivery to the following recipients failed due to a permanent error" "Remote host said: 550 This system has been configured to reject your mail (B)".
BR,
Mohammed Mahmoud.
Hi Mohammed,
it is very nice answer. Can you explain the relationship between ping's TTL and count of hops in traceroute? When I tried something, I thing that it is
ping's TTL == traceroute hops - 2.
Is it correct? And why it is so? But in my images from terminal it is not so always. Thank you very much!
Terminal: ping's TTL and traceroute
