AddRoute failed to add a route: code 65
Jan 14th, 2008
I have seen many questions and answers about "AddRoute failed to add a route: code 87". However, I have got this error "AddRoute failed to add a route: code 65" . Do anyone know the reason??
30 14:27:23.436 01/14/08 Sev=Info/4 CM/0x63100034
The Virtual Adapter was enabled:
IP=172.18.96.18/255.255.0.0
DNS=130.1.147.88,130.1.90.22
WINS=0.0.0.0,0.0.0.0
Domain=
Split DNS Names=
31 14:27:23.436 01/14/08 Sev=Warning/2 CVPND/0xE3400013
Destination 192.168.1.0
Netmask 255.255.255.0
Gateway 172.18.96.18
Interface 172.18.96.18
tstanik Tue, 01/22/2008 - 09:22
  • Bronze, 100 points or more
This error typically occurs if there is an attempt to add a duplicate route to the routing table where an entry already exists for this. Do the following to check this
a) Close the VPN Client.
b) ipconfig /release
c) ipconfig /renew
d) Launch VPN Client and attempt another connection.
zoheb sarwar Fri, 02/01/2008 - 11:59
I tried the above steps but the problem still persists.
I have several clients that connects to the ASA (8.0). Some of the client have got this issue that after reconnect the route addition fails. But if I restart the pc every thing works fine.
This is happening to 3 out of 200 vpn clients.
Please suggest
