EIGRP and BGP
Jan 14th, 2008
when EIGRP and BGP is flapping.
which portion should I check to find out
if it is flapping because of high traffic or low quality access lines?
which should config should I check?
thanks a lot
Lucien Avramov Thu, 02/07/2008 - 14:15
This is too vague. Check your console messages and start from there. think lawerwise, check your crc errors on the interfaces and your cables, if your quality of communication is bad protocols indeed will misbehave and for example have timers time out.
