Cisco 871 and VDSL
Jan 14th, 2008
I try to install a Cisco 871 Router to connect to T-Home VDSL. But I do not get it to work. Now I read that Cisco does not support VDSL. Ist this still true??
Paolo Bevilacqua Tue, 01/15/2008 - 01:43
Cisco support ADSL over pots, some model supports annex M. 871 has an ethernet interface. What is VDSL ?
claudioham Tue, 01/15/2008 - 10:31
Very High Data Rate Digital Subscriber Line.
Makes (theoratically) up to 53 MBit/s and you can have it here in Germany for Internet and TV over Internet.
Paolo Bevilacqua Tue, 01/15/2008 - 11:40
Hi, I've looked around and it seems very few vendors have VDSL modems/router, zyxel and avm are exceptions.
Cisco has VDLS products but calls them LRE. It is not a consumer grade product and I don't think is interoperable with other vendors.
So to use your 871 on VDSL you will need to front-end it with a third-party VDSL modem/bridge.
wochanda Tue, 01/15/2008 - 12:48
871 doesn't support ANY DSL, because it only has ethernet interfaces. I'm assuming you're connecting a DSL modem to the WAN port of the router to make this work, which means the router isn't "doing VDSL".
Do you need to do PPPoE or something?
