global NAT conflect global NAT conflect global NAT conflect
Jan 15th, 2008
hello,
i have configured my ASA 5510 for nat as:
global (outside) 1 55.55.55.11-55.55.55.15 netmask 255.255.255.0
global (outside) 1 55.55.55.100-55.55.55.160 netmask 255.255.255.0
nat (inside) 1 192.168.15.0 255.255.255.0
static (inside,outside) 55.55.55.11 192.168.15.11 netmask 255.255.255.255 dns
static (inside,outside) 55.55.55.13 192.168.15.13 netmask 255.255.255.255
static (inside,outside) 55.55.55.15 192.168.15.14 netmask 255.255.255.255
static (inside,outside) 55.55.55.159 192.168.15.99 netmask 255.255.255.255
static (inside,outside) 55.55.55.78 192.168.15.78 netmask 255.255.255.255
static (inside,outside) 55.55.55.14 192.168.15.15 netmask 255.255.255.255
but i have 2 different IPs share same IP 55.55.55.14 is that possible?
any help please.
Global 55.55.55.14 Local 192.168.15.15
Global 55.55.55.14 Local 192.168.15.239
jbayuka Tue, 01/22/2008 - 08:24
  • Bronze, 100 points or more
I do not think that it will work. You need to use separate pair for second static entry.
