CM - Topology Filter "PoE Devices" is not showing the correct devices.
Jan 15th, 2008
What is the criteria for devices to be highlighted when you select the Topology Filter "PoE Devices" in the Network topology view in CM ?
Is it on device type or does the device need to respond on MIB queries on the POWER-ETHERNET-MIB ?
I have devices that don't have PoE, but they are highlight when I select the Topology Filter "PoE Devices" and I also have an 3560 that doesn't get highlighted (and it has PoE).
If I try to configure PoE on the 3560 from CiscoView, CiscoView has no problem with seeing it as an PoE Devices.
Can someone tell me how the Topology Filter "PoE Devices" are selecting devices ?
Best regards
John
Overall Rating: 5 (1 ratings)
Joe Clarke Tue, 01/22/2008 - 11:04
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The PoE filter is based on device type. The list of types are stored in NMSROOT/campus/main/filters/POECapableDeviceTypes.properties. These types correspond to the label type you see in Campus Manager.
ROMAN TOMASEK Mon, 12/07/2009 - 02:25
the customer has the same problem:-( He doesn't see the 2960 PoE with filter enabled in the topology view:-( I cann't to find your file:
In the campus folder are following folders: bin, etc, lib and www.
Thank you
Roman
Joe Clarke Mon, 12/07/2009 - 09:01
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please start a new thread for your issue.
