IN archive managment I am getting this error when I have cross credintials
Jan 15th, 2008
"CM0060 PRIMARY RUNNING Config fetch SUCCESS for
wsd15231.netiss.intesabci.net, version number 3
archived.CM0057 VLAN RUNNING Config fetch SUCCESS, archival
failed for wsd15231.netiss.intesabci.net Cause: CM0012:
Unable to create new version on archive $1 Action: Check if
disk space is available and directory has required
permissions Action: Verify that archive exists for device. "
Overall Rating: 5 (1 ratings)
Joe Clarke Tue, 01/15/2008 - 13:36
Assuming akemp's suggestions check out, you are most likely hitting the bug CSCsh39475. This bug is fixed in RME 4.0.6 and RME 4.1. Once you have upgraded to a fixed version, you will need to delete then re-add the device within RME to complete the fix.
shamrockfoods Thu, 10/15/2009 - 09:19
Ran into this myself. In RME, do you delete devices under RME or Normal devices or does that matter? If its locked in with DCR, does that matter like it does w/ DFM?
Joe Clarke Thu, 10/15/2009 - 09:20
Delete under RME > Devices > Device Management > RME Devices. As long as you do not remove it from DCR, it will not affect other LMS applications.
shamrockfoods Thu, 10/15/2009 - 09:49
Thanks Joe! What is the interval that RME uses where it will re-add them from DCR?
