How can I check the virtual-address up using show command in ACE?
Jan 15th, 2008
I want to check the virtual-address using show command.
however, there are not in ACE. So I used the ping to check virtual-address status in ACE
I want to know the command what is verify virtual-address status , using show command
Thank :)
Roble Mumin Tue, 01/15/2008 - 04:14
  • Bronze, 100 points or more
Try -> show arp
There you have a Type column and a Status column.
Look for the entry "VSERVER" in the Type column
Roble
