RME 4.05 with LMS 2.6-Device Update
Jan 15th, 2008
I am having problem in updating the device packages for RME 4.05 in LMS 2.6 .
I tried chaging the TEMP path to C:\Windows\Temp. I could update the packages once, but again facing the same problem. I also tried by changing the Temp path to some other directory but still facing the same problem.
Is there any solution for this problem?
deshmukh_shivaji Tue, 01/15/2008 - 23:29
I am not getting any specific error,
"Error while installing "
Same error from Both GUI as well as CLI
deshmukh_shivaji Thu, 01/17/2008 - 01:50
During normal device package update process without errors it is observed that file size and contents of Temp dir keep on changing.
But during failed proccess there is no change happening with Temp dir.
