how to change configuration using SNMP
Answered Question
Jan 15th, 2008
i have 3560 device on remote site and due to some wrong configuration tacac communication is getting failed and switch is now directly asking for password however it gives authorization failed when i put in.
is there any way by which i can fetch the config via snmp and change configuration and reconfigure the switch.
i tried using cwconfig features but getting authentication failed error is popping up.
Correct Answer by David Stanford about 9 years 2 months ago
You can use any snmp utlity...you would just query / set the same snmp OID's
Overall Rating: 4 (2 ratings)
roger.malik Tue, 01/15/2008 - 07:25
Hi davistan,
this require hpopenview and solaris. i dont have any of them, is this still possible ?
Correct Answer
David Stanford Tue, 01/15/2008 - 07:38
  • Cisco Employee,
