Cisco VLAN 1
Jan 15th, 2008
What is Cisco Recommendation for VLAN 1. Is there any issues with Keeping VLAN 1. Is this a security Risk. I am looking for a good Document on weather to Keep the Cisco vlan 1 or rename it allto gather. What is Cisco stance on this?
Jon Marshall Tue, 01/15/2008 - 07:51
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Janet
Cisco recommend using a separate vlan for managing your switches ie. don't use vlan 1 on the switch for remote access, and they also recommend putting all unused ports into a dummy vlan with no layer 3 interface - we use vlan 998 here where i work.
Note the vlan 1 will still be used by PagP, CDP, STP to send information down trunk links.
Attached is a paper on vlan security with a specific part on use of vlan 1.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_white_paper09186a008013159f.shtml
Jon
