Cisco PIX 515E
Jan 15th, 2008
If I upgrade my Cisco PIX 515E to Version 7.2 will I be able to leverage the WebVPN feature? In other words, with an upgrade to the version for my PIX 515E is the SSL VPN functioonality an option?
srue Tue, 01/15/2008 - 09:17
PIX doesn't support webvpn/sslvpn, even with 7.x or later OS. You need an ASA device for that.
JORGE RODRIGUEZ Wed, 01/16/2008 - 07:38
Hi Steven, I didn't know this , so even if PIX runs code 7.x or 8.x this feature is not supported ?.. I would assume this will apply to all PIX 515s,525s,535s platforms etc.., good to know specially if end user out there upgrades PIX codes to hope using this feature.
srue Wed, 01/16/2008 - 10:18
Even if pix runs 7.x or 8.x, ssl vpns will NOT be supported. and yes, it applies to all PIX platforms.
