Wired guest access - Unable to access network
Jan 15th, 2008
I've configured two WLC's with the exact same config one of them has working Wired guest network the other one does not.
The only difference in the two I know of is that the one that does not work is connected to a Cisco 3550 switch, the one that works is connected to a Cisco 7600.
The problem is when I connect a computer to the wired guest network I am able to get an IP address from the Internal DHCP server but unable to access the network.
I've tried pinging the gateway's IP and I get no answer.
The Port-channel interface has the correct VLans and the vlans exist on all switches.
If anyone see an error there or might have an idea why this is not working I would appreciate the feedback.
Config follows below..
regards,
Gk
gudmundurk Tue, 01/15/2008 - 08:13
(Cisco Controller) >show running-config
802.11a cac voice tspec-inactivity-timeout ignore
802.11a cac voice stream-size 84000 max-streams 2
802.11b cac voice tspec-inactivity-timeout ignore
802.11b cac voice stream-size 84000 max-streams 2
location rssi-half-life tags 0
location rssi-half-life client 0
location rssi-half-life rogue-aps 0
location expiry tags 5
location expiry client 5
location expiry calibrating-client 5
location expiry rogue-aps 5
Cisco Public Safety is not allowed to set in thisdomain
ap syslog host global 255.255.255.255
auth-list ap-policy ssc enable
custom-web ext-webserver add 1 217.28.176.114
dhcp create-scope guestnetwork
dhcp address-pool guestnetwork 192.168.34.2 192.168.34.200
dhcp default-router guestnetwork 192.168.34.254
dhcp enable guestnetwork
dhcp dns-servers guestnetwork 212.30.200.200 212.30.200.199
dhcp network guestnetwork 192.168.34.0 255.255.255.0
local-auth method fast server-key *****
interface create guestnetwork 331
interface create guestnetwork-wired 332
interface address ap-manager 10.255.255.90 255.255.255.248 10.255.255.94
interface address dynamic-interface guestnetwork 192.168.34.1 255.255.255.0 192.168.34.254
interface address dynamic-interface guestnetwork-wired 192.168.35.1 255.255.255.0 192.168.35.254
interface address management 10.255.255.89 255.255.255.248 10.255.255.94
interface address service-port 10.60.4.200 255.255.255.0
interface address virtual 1.1.1.1
interface dhcp ap-manager primary 10.255.255.89
interface dhcp dynamic-interface guestnetwork primary 10.255.255.89
interface dhcp management primary 10.255.255.89
interface dhcp service-port disable
interface vlan ap-manager 226
interface vlan guestnetwork 331
interface vlan guestnetwork-wired 332
interface vlan management 226
interface port ap-manager 29
interface port guestnetwork 29
interface port guestnetwork-wired 29
interface port management 29
lag enable
load-balancing window 5
mesh security eap
mgmtuser add root **** read-write
mobility group domain XXXXXXX
mobility symmetric-tunneling enable
network otap-mode disable
network rf-network-name XXXXXXX
radius acct add 1 XXXXXXX 1813 ascii ****
radius auth add 1 XXXXXXX 1812 ascii ****
radius auth management 1 disable
spanningtree port mode off 1
spanningtree port mode off 2
sysname XXXXXXX
time ntp interval 3600
time ntp server 1 XXXXXXX
wlan create 1 hotspot hotspot
guest-lan create 1 hotspot-wired
wlan interface 1 guestnetwork
guest-lan interface 1 guestnetwork
wlan custom-web webauth-type external 1
wlan custom-web ext-webauth-url https://XXXXXXX
wlan session-timeout 1 disable
wlan wmm allow 1
wlan wmm allow 18
wlan security wpa disable 1
wlan security wpa disable 18
wlan radius_server auth add 1 1
wlan radius_server acct add 1 1
guest-lan radius_server auth add 1 1
guest-lan radius_server acct add 1 1
wlan dhcp_server 1 0.0.0.0 required required
wlan enable 1
guest-lan enable 1
Trending Topics - Security & Network
