Radius Authorization
Jan 15th, 2008
I've juste configured port based authentication on switches,and it was completed successfully,I applied per users ACL using AV-PAIR for authorizing users.
when verifying the switch all things are correct.
I want to do the same thing to limit access for wireless users, I've 2 vlans in an AP 1130,configured with 802.1X also.I've tried the downloadble acl, the AV-PAIR attribute and the filter id in radius attribute but no restriction is applied.
can I've some help?
Overall Rating: 2.5 (2 ratings)
jbayuka Tue, 01/22/2008 - 09:27
AAA authorization enables you to limit the services available to a user. When AAA authorization is enabled, the network access server uses information retrieved from the user's profile, which is located either in the local user database or on the security server, to configure the user's session. Once this is done, the user will be granted access to a requested service only if the information in the user profile allows it.
