Poor Voice Quality
adam.staub
I'm experiencing poor voice quality between my home office and a remote. The offices are connected via a dedicated T-1. The home office is using a 3745 and the remote is running a 3725. QOS is setup as follows:
class-map match-all termserv
match access-group 103
class-map match-all video
match access-group 112
class-map match-all voice
match ip precedence 5
policy-map wan-outbound
class voice
priority 350
class termserv
bandwidth 375
class video
bandwidth 256
This map is applied to the serial interfaces on the routers.
Output of show policy-map:
Policy Map wan-outbound
Class voice
Strict Priority
Bandwidth 350 (kbps) Burst 8750 (Bytes)
Class termserv
Bandwidth 375 (kbps) Max Threshold 64 (packets)
Class video
Bandwidth 256 (kbps) Max Threshold 64 (packets)
AutoQos is enabled on the 3550 switches on both ends. Not sure where to start.
Aaron Dhiman
Level 2
Level 2
You're almost there. Try "show policy-map interface"
Here is interface output.
Service-policy output: wan-outbound
Class-map: voice (match-all)
30365502 packets, 1979524828 bytes
30 second offered rate 110000 bps, drop rate 0 bps
Match: ip precedence 5
Queueing
Strict Priority
Output Queue: Conversation 264
(pkts matched/bytes matched) 6539578/435104296
(total drops/bytes drops) 0/0
Class-map: termserv (match-all)
66417646 packets, 20265473980 bytes
30 second offered rate 254000 bps, drop rate 0 bps
Match: access-group 103
Queueing
Output Queue: Conversation 265
(pkts matched/bytes matched) 24700539/15267830729
--More-- (depth/total drops/no-buffer drops) 2/1225/0
Class-map: video (match-all)
3043410 packets, 2624179575 bytes
30 second offered rate 0 bps, drop rate 0 bps
Match: access-group 112
Queueing
Output Queue: Conversation 266
(pkts matched/bytes matched) 1673799/1383582275
(depth/total drops/no-buffer drops) 0/918/0
Class-map: class-default (match-any)
71950643 packets, 94351715773 bytes
30 second offered rate 768000 bps, drop rate 0 bps
Match: any
Well, the problem is not with your Priority Queue bandwidth configuration. You have no drops in that queue.
Can you set up a call that has poor quality. Then on both ends paste output for "sh call active voice brief"-->just pull out the info for the call in question. There should be two legs associated with the call.
Also, we'll need the "show policy-map int" from the other side as well...
