ASDM 6 bugs
Jan 15th, 2008
Upgraded ASA to 8 with ASDM 6 and noticed the following oddities in the new ASDM.
Configuration -> Remote Access VPN -> IPSec Connection Profiles -> Enable interfaces for IPsec access. The checkbox for outside is not checked even though it is enabled.
Configuration -> Site to Site VPN -> Connection Profiles. Only 1 of my tunnel groups is showing up in the list even though there are 3 in the config.
acomiskey Wed, 01/16/2008 - 06:53
Found another one...
Configuration -> Site to Site VPN -> Connection Profiles. The 1 tunnel group which is showing up says IPsec protocol is Disabled. This is not true.
Anyone else see these issues after going to 8?
acomiskey Thu, 01/17/2008 - 11:44
...and another one...
Monitoring -> VPN Statistics -> Sessions -> Bytes TX/RX
The byte counter used to add all of the ipsec sessions together, now it seems to just pick one. For example, if I have multiple interesting traffic acl's defined for a site to site tunnel, ASDM 5 would add all the traffic together. ASDM 6 just seems to pick one of the acl's.
I want ASDM 5 back!
