cisco 2960 backup
Answered Question
Jan 15th, 2008
I am currently backing up the startup configuration file on all our switches.
What files are needed to recover from a switch failure? That is if it needed to be replaced by a new switch.
jason
Correct Answer by plumbis000 about 9 years 1 month ago
I would backup the startup-config, vlan.dat file and the IOS image (depending on the replacement device)
Overall Rating: 5 (1 ratings)
Correct Answer
plumbis000 Tue, 01/15/2008 - 11:01
