frame-relay payload-compression
Answered Question
Jan 15th, 2008
Hi, does anyone know the difference between the packet-by-packet vs frf9stac parameters for this command?
Lisa G
Correct Answer by aghaznavi about 9 years 6 months ago
1.Payload compression on each VC consumes approximately 40 kilobytes for dictionary memory.
2.FRF.9 compression uses relatively higher compression ratios, allowing more data to be compressed for faster transmission. FRF.9 compression provides the ability to maintain multiple decompression/compression histories on a per-DLCI basis.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a0080080fdc.html#wp1066773
Overall Rating: 5 (1 ratings)
Correct Answer
aghaznavi Tue, 01/22/2008 - 09:31
  • Silver, 250 points or more
