Clients will drop off of WLAN at steady intervals
Jan 15th, 2008
I have two 2006 series WLC's and 5 ap's on both. I have a WLAN for public use that has only web authentication for security. (This WLAN has internet only, nothing else. Its used for testing.) When users authenticate, everything works for about an hour, then they drop and it takes 10-15 minutes to come back up. Then their good for about another hour.
WHAT IVE DONE:
--There is no QoS running on the the open WLAN
--Changed the client roaming profile:
Minimum RSSI -- -85
Hysteresis -- 4
Scan Threshold -- -72
Transition Time -- 1
Is there anything you guys can help me with? Thanks in advance!
Scott Fella Tue, 01/15/2008 - 14:15
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
If the infrastructure is not the issue, try changeing the value on the idle timeout (located on the Controller | General tab) or the session timeout on the WLAN SSID.
Scott Fella Tue, 01/15/2008 - 15:28
  • Hall of Fame,
    2017 Wireless
Try setting it to 28800. That would be 8 hours.
Scott Fella Tue, 01/15/2008 - 15:38
  • Hall of Fame,
    2017 Wireless
what code are you running.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
