PIX 501 VPN
Answered Question
Jan 15th, 2008
Hi, I just got my PIX configured based on the clear/great instruction I have recieved from one of you this morning. Now, I am trying to set up VPN, I looked at Cisco site (http://cisco.com/en/US/products/hw/vpndevc/ps2030/prod_configuration_examples_list.html#anchor14) but could not figure out which one I need to follow. Would you please send me the instruction or link to set up vpn? By the way, I don't have the vpn client to test my vpn, how do I get that? As you can understand from my question I am new to cisco gears...thank you.
Correct Answer by pjhenriqs about 9 years 2 months ago
I am guessing that you need one of these two VPNs.
- Remote access VPN: where remote users can use Cisco VPN client to access the company resources
- Site-to-site VPN: where two IPSEC capable devices establish a VPN tunnel, allowing internal LANs from different endpoints (offices) to communicate.
You can find both examples on the url you gave.
If it's remote access, I would look at
http://cisco.com/en/US/products/ps6120/products_configuration_example09186a0080702992.shtml
And then look also at how to configure split tunneling, so the user at home can access the corporate resources AND the Internet.
For the site-to-site VPN, it depends if your other device is a PIX/ASA or a Router.
Hope it helps,
Paulo
Overall Rating: 5 (1 ratings)
Correct Answer
pjhenriqs Wed, 01/16/2008 - 06:22
Hope it helps,
Paulo
as1207dc01 Wed, 01/16/2008 - 07:45
ok, configuration is complete. How do you help me find Cisco vpn client to test my configuration? .... Thank you for your help.
pjhenriqs Wed, 01/16/2008 - 08:00
The Cisco VPN Client is available on the Cisco website to download. Just search for "Software Download" and it should come up. I believe the category where to find the software should be "VPN" or "Security" (i don't remember exactly).
Paulo
as1207dc01 Wed, 01/16/2008 - 08:05
well, it has a lock on it. I think I need to have smartnet account. It seems I am stuck.
