AP 1250 CLI command
Jan 15th, 2008
What's the command to enable ssid's broad cast.
All I see is GUI examples in the doc's, but no cli examples.
denis.roy Wed, 01/16/2008 - 12:49
I looked at it; I didn't see any cli commands to enable or disable broadcasting ssid's.
rob.huffman Wed, 01/16/2008 - 16:57
Hi Denis,
This command that Scott correctly noted does enable the SSID to be broadcast;
Step 6 guest-mode
(Optional) Designate the SSID as your access point's guest-mode SSID. The access point includes the SSID in its beacon and allows associations from client devices that do not specify an SSID.
Give it a try :) It doesn't mention broadcast but this is what it actually means.
rob.huffman Mon, 01/21/2008 - 06:48
Hi Denis,
They couldn't just say something nice like "enable Broadcast ssid"
It's always something isn't it :)
Take care,
