Disabling forwarding calls to each other
Overall Rating: 5 (1 ratings)
Rob Huffman Tue, 01/15/2008 - 16:06
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Julio,
This issue has not yet been fixed, this is a known bug (feature request). For the time being you will have to educate your users to be careful when forwarding;
CSCds43736 Bug Details
Headline Feature Req: Call Fwd loops should be handled gracefully by CM
Product ciscocm
First Found-in Version 3.0(3a)
Status Assigned
Feature request:
When two or more phones are forwarded to create a forward loop CM will
tear down the call when it reaches the ForwardMaximumHopCount.
The CM should handle this as follows:
PhoneA fwd Phone B
PhoneB fwd Phone C
PhoneC fwd Phone A
When you call Phone A from Phone X the Call Manager will ignore the loop and
Phone C will ring.
Following the same principle when Phone B is called, the call should go to
Phone A as it is the last hop before the loop.
From this good doc;
Cisco CallManager Issues with Call Forward All
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801b3f4b.shtml#t5
Hope this helps! Sorry man.
Rob
Rob Huffman Tue, 01/15/2008 - 18:26
  • Hall of Fame,
    Founding Member
Hi Julio,
You are most welcome :) There are some tips for mitigating this issue in this good doc;
Cisco CallManager Loop Avoidance Guide to Best Practices
http://www.cisco.com/en/US/netsol/ns340/ns394/ns165/ns391/networking_solutions_design_guidance09186a00801f8e28.html#wp41158
And there is hope on the horizon in CCM 6.x, although I understand there are still a few wrinkles to work out;
Call Forward All Loop Prevention Message Changes
Changes for the following error messages that display on the phones for Call Forward All (CFA) loop prevention occurred:
•When a user activates CFA from a phone, resulting in a CFA loop:
-Original error message: "Call Forward Loop"
-New error message: "CFwdAll Loop Detected"
Release Notes for Cisco Unified Communications Manager Release 6.0(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_0_1/601cmrn.html#wp80207
Hope this helps!
Rob
Aaron Dhiman Wed, 01/16/2008 - 10:13
Given this bug, if your users hop around a lot, you might just have them use Extension Mobility instead...
