WIC Configuration help
I have two locations 1 Seattle 1 Houston,
Houston Router 3725
Seattle Router 3825
I have the FastEhternet 0/0 configured with an ip of 10.100.X.254 mask
the Serial0/0 Configured with IP 10.101.X.254 mask
I get an error someting to the affect %X.X.X.X overlaps the fastethernet port
when I hit enter.
Hieu Cao Tue, 01/15/2008 - 16:42
Can you try this:
Fastethernet: mask
Serial: mask
chris_tan Tue, 01/15/2008 - 18:57
I assume you use mask for your FE. So the total available subnet you can use is - This is a huge subnet, I would suggest you lower down it to if you do not require that big subnet.
As for the Serial, I assume you are using
FYI, most point-to-point link just require not more than 2 host, so please use (other available IP is It just my opinion.. you can still use if you want. :-)
Note: there is a good online subnet calculator you can use --> http://www.subnet-calculator.com/
Hope it help.
Chris -
thaks for the help. no love yet I am going to include both run configs
Thanks for any help you can provide
Building configuration...
version 12.3
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname X
ip cef
ip domain name X.com
ip audit po max-events 100
interface FastEthernet0/0
ip address
duplex auto
speed auto
interface Serial0/1
ip address 10.101.X.254
ip access-group 100 in
ip access-group 100 out
encapsulation ppp
service-module t1 clock source internal
ip http server
ip http secure-server
ip classless
ip route Serial0/1
ip route Serial0/1
access-list 100 permit tcp any any log
access-list 100 permit udp any any log
access-list 100 permit icmp any any
access-list 100 permit ip any any
Current configuration : 2306 bytes
version 12.4
hostname X
logging buffered 51200 warnings
enable secret 5 $1$oQKz$UT.TBMuajHknOST36UcgO.
interface GigabitEthernet0/0
ip address 10.10.X.10
duplex auto
speed auto
media-type rj45
negotiation auto
no mop enabled
interface Serial0/0/0
ip address 10.101.X.253
encapsulation ppp
ip classless
ip route Serial0/0/0
ip http server
ip http authentication local
dialer-list 1 protocol ip permit
chris_tan Wed, 01/16/2008 - 18:34
1) Housotn router config.
- why access-list 100 implement in s0/1 since the acl is allow all? Are you trying to see the traffic flow ?
- you do not need "ip route Serial0/1" because the default route will take care of it
What do you mean "you discovered traceroute on other (working) T1" ? Does it mean in seattle router have others WAN link?
