pix at home
Answered Question
Jan 15th, 2008
i brough a extra pix506e we had at the office home so i can play with the VPN client software.
I cannot get my computers (3) at home to get internet access. they get internal ip addresses but for some reason i cannot connect to the internet!
Below is my configuration!
Also my IP address at home is dynamic NOT STATIC!
any ideas?
PIX Version 6.3(3)
interface ethernet0 10full
interface ethernet1 10full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname pixfirewall
domain-name ciscopix.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
pager lines 500
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 10.9.2.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 10.9.2.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 10.9.2.200-10.9.2.210 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
Cryptochecksum:xxx
: end
I have in the past seen problems with cable modems and dhcp/new equipment. Have you tried to turn off the cable modem and PIX. Wait some time (30-60 min.) turn on the modem and after a couple of minutes turn on the PIX.
Sometimes it is nessesary to call your ISP and get them to release the DHCP lease, or register the MAC address of the new equipment.
Hope it helps.
Overall Rating: 5 (1 ratings)
srue Tue, 01/15/2008 - 18:52
  • Blue, 1500 points or more
at first glance the config looks OK.
do you get an ip address on the outside interface, "show ip".
add the following to allow pings to the Internet:
access-list OUTSIDE_IN permit icmp any any echo-reply
access-group OUTSIDE_IN in interface outside
then try to ping 4.2.2.4
(that's a top level DNS server). If that doesn't work, try to ping it from the firewall.
is there a reason you hardcoded the speed/duplex?
Danny Guillory Jr Tue, 01/15/2008 - 19:52
when i do a show ip i get:
no ip address outside
for both current ip address & system IP address
i did not hardcode the IP speed. this router had a old config on it. so to clear it i did a:
configure factory-default 10.9.2.1 255.255.255.0
and for some reason it did that be itself! I THINK.
srue Wed, 01/16/2008 - 05:32
you're not getting an IP address on the outside then.
change the interface(s) to auto:
interface ethernet0 auto
interface ethernet1 auto
then re-enter the following:
Danny Guillory Jr Wed, 01/16/2008 - 16:13
Here is my PIX configuration. I still am not getting a IP address from the cable modem?
any ideas?
PIX Version 6.3(3)
enable password xxx
passwd xxx encrypted
names
pager lines 500
mtu outside 1500
mtu inside 1500
pdm history enable
arp timeout 14400
http server enable
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd lease 3600
dhcpd enable inside
terminal width 80
Cryptochecksum:xxx
: end
Correct Answer
Hope it helps.
