Switches for CCIE R&S labs
Answered Question
Jan 15th, 2008
Hello!
I want to buy 2x 3550 and 2x 3560 switches. I am a bit confused about the 3550s. On eBay I found many relatively cheap 3550-SMIs which have the EMI image installed. My question with regards to the CCIE labs, would I have any disadvantage buying these SMI switches with EMI image installed? Is that even allowed?
Or should I stay away from those, and get the real EMI switches instead?
Thanks in advance!
Sascha
Correct Answer by srue about 8 years 10 months ago
yes, that's what it means. Previous switches were tied to SMI or EMI in the hardware, not the 3550/3560.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_see/release/notes/OL8556.html
Overall Rating: 5 (1 ratings)
srue Tue, 01/15/2008 - 18:41
the 3550's and 3560's are software upgradeable to EMI. The EMI images are referred to as IP Services and SMI images are referred to as IP Base.
In otherwords, purchasing a 3550-SMI with an EMI image installed, is just fine technically. I won't comment on whether or not Cisco is OK with it.
I just acquired a 3550-48-SMI today actually and upgraded it to the EMI (IP services) image w/ crypto.
For the 3560, I believe the R/S lab uses the Adv. Ip Services image, which looks to me like it is the IP Services image, plus IPv6.
sascha_wintz Tue, 01/15/2008 - 18:47
Thank you both for your comments!
Does this mean that the 3550-SMI w/ EMI image is equal in terms of software functionality to the 3550-EMI switch?
Thanks!
