Formating the internal flash simm on a 3640 router
Answered Question
Jan 15th, 2008
I have a a cisco 3640, It had 16MB of flash memory, but I put in another flash simm to make it 32MB, not the router is not able to boot properly. The error message it produces states that the flash in unknown or needs to be formated. It has not been able to boot properly since and into Rommon, even when I only install the original 16MB simm. Is there a way to format the whole 32MB in Rommon?
Correct Answer by htarra about 9 years 5 months ago
It is not possible to exchange Flash cards between all devices
and "Flash card must have been formatted in the target platform."
see "PCMCIA Filesystem Compatibility Matrix and Filesystem Information"
http://www.cisco.com/en/US/products/hw/routers/ps341/products_tech_note09186a00800a7515.shtml
Cisco recommends to use the "copy tftp flash:
partition>:" command when you have partitions on the flash.
- First if possible try to format
Formatting Compact Flash Memory Cards
http://www.cisco.com/en/US/products/hw/routers/ps259/products_configuration_guide_chapter09186a008007e5fb.html
Overall Rating: 5 (1 ratings)
Correct Answer
htarra Tue, 01/22/2008 - 10:06
  • Bronze, 100 points or more
reachonenetadm Fri, 02/22/2008 - 13:14
I have a very similar situation. I've upgraded from 2x8MB flash SIMMS to 2x16Mb flash SIMMS. It will only boot to ROMMON. Xmodem transfer says:
rommon 7 > xmodem -c c3640-jk9s-mz.124-16.bin
Do not start the sending program yet...
bus error while trying to access flash - addr = 0x30000000
cannot read flash info
getdevnum warning: device "flash" has size of zero
open: read error...requested 0x4 bytes, got 0x0
trouble reading device magic number
dir: cannot open device "flash:"
WARNING: All existing data in flash will be lost!
Invoke this application only for disaster recovery.
Do you wish to continue? y/n [n]: y
I can put the old SIMMS back in and it boots fine. Any ideas how to format the SIMMS from ROMMON or other ways out of this?
mayambanzumba Fri, 02/22/2008 - 16:48
I managed to fix this problem. I had two new 16MB simms. I booted into rommon and used xmodem to upload the flash file to the router. I think the router formats the flash whilst copying. I have noticed that you are trying to Xmodem a large file (12.4). It will take a rather long time with xmodem. I used xmodem to copy a 12.1 IOS and then upgraded later to 12.4 when I successfully booted from 12.1. Try xmodem with a smaller IOS, I think this enables the router to format the flash byte by byte before copying the image, it worked for me.
