wlc 2106 problem ( cant connect to 2 lwapp ( 1242 & 1131 ) need advice
heru_hermawan
Dear All,
could you give me some advice to configure wlc with 2 lwapp,
i did try to used 1 lwapp ( 1242 ag ) and it's work, but when i try to connect with 2 lwapp ( 1242 & 1131 ), i can't associated with lwapp 1131 ag, i did used same configuration for both,
need youd advice and reference guide for this issue.
thanks and regards
ankbhasi
Hi Heru,
If both are lwapp aps then they should be able to join 2106 controller. Can you confirm if 1130 is also connected to same subnet where 1242 is connected? Is management subnet/vlan different from the vlan you are connecting your LWAPP APs.
Hope this link should help
http://www.cisco.com/en/US/docs/wireless/controller/4.2/configuration/guide/c42lwap.html#wp1104685
Ankur
*Pls rate all helpfull post
