ASA 5505
Answered Question
Jan 15th, 2008
Hello guys,
I'm planning to buy a ASA 5505. However I'm not sure that I can setup this device with 3 inyerface outside, inside, and DMZ. Does it allow to have 3 ports used for these purposes or only two ports for outside and inside ?
Kind of confused. Because pictures shows that there are 8 FE. However it is not clear that there are whether switch ports or not.
Thanks for your help and time...
Correct Answer by pjhenriqs about 9 years 4 months ago
As you can see from the following links you can configure a DMZ with the ASA 5505:
http://www.cisco.com/en/US/docs/security/asa/asa72/getting_started/asa5505/quick/guide/dmz.html#wpxref96382
Also, you can check how the ASA5505 looks like:
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/ps6913/prod_presentation0900aecd805ac1dd.html
Hope it helps,
Paulo
Overall Rating: 5 (1 ratings)
Correct Answer
pjhenriqs Wed, 01/16/2008 - 02:30
Hope it helps,
Paulo
