switch specifications
Jan 16th, 2008
1.48 numbers of 10/100/1000 base T COPPER PORTS ,24 NUMBERS OF 1000 BASE X SFP FIBER PORTS TO PLUG IN MULTIMODE OR SINGLE MODE FIBER TRANSCEIVERS.
SWITCHING PERFORMANCE.
1.THE CORE SWITCH SHOULD BE MODULAR/CHASSIS BASED WITH REDUNDANT POWER SUPPLIES.
2.THE SWITCHING ENGINE SHALL HAVE A SWITCHING SPEED OF AT LEAST 156 GBPS.
3.THE CORE SWITCH SHOULD HAVE A PERFORMANCE /THROUGHPUT OF AT LEAST 136 MBPS.
4.THE SWITCH SHOULD BE CAPABLE OF TAKING 10G PORTS BY ADDING CARDS/TRANSCEIVERS.
PLZ SUGGEST ME BEST SWITCH.
ankbhasi Wed, 01/16/2008 - 00:45
  • Cisco Employee,
Hi Ramlal,
Only thing that comes to my mid is 6509-E switch with sup 720.
http://www.cisco.com/en/US/products/ps6777/index.html
http://www.cisco.com/en/US/products/hw/modules/ps2797/ps5138/index.html
When you open the link above on left hand side down you will see data sheet for different line cards, just click to get more details about fifferemt line card module supported.
Check the data sheet for sup 720
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_data_sheet09186a0080159856_ps2797_Products_Data_Sheet.html
Data sheet for 10/100/100 ethernet modules
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_data_sheet0900aecd8017376e_ps2797_Products_Data_Sheet.html
But if budget is a concern you can think of 4500 E series chassis
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/product_data_sheet0900aecd801792b1.html
http://www.cisco.com/en/US/prod/collateral/modules/ps2710/ps5494/product_data_sheet0900aecd802109ea_ps4324_Products_Data_Sheet.html
Ankur
*Pls rate all helpfull post
ramnetindia Wed, 01/16/2008 - 02:05
I WANT THIS SPEFICATIONS ALSO.
plz suggest me.
1.LAYER 3 FUNCTIONALITY...
A)THE CORE SWITCH SHOULD SUPPORT ABOUT 1024 VLANS (SUBNET BASED)
B)THE SWITCH SHOULD SUPPORT INTER VLAN ROUTING FOR TCP/IP,ETC.
c)THE CORE SWITCH SHOULD SUPPORT ROUTING PROTOCOL RIP VER1&VER2,OSPF AND OSPF ECMP (EQAL COST MULTI PATH)
d)THE CORE SWITCH SHOULD SUPPORT MULTICAST ROUTING PROTOCOL PIM-SM AND DVMRP
e)THE CORE SWITCH SHOULD SUPPORT IPV4 & IPV6.
ACL.....
THE CORE SWITCH SHOULD ACCESS CONTROL LISTS PER PORTS BASED ON
a) MAC ADDRESS
B) IP ADDRESS (SOURCE & DESTINATION).
c) ICMP TYPE,
d) TCP/UDP PORTS
QOS....
a)THE CORE SWITCH SHOULD BE ABLE TO HANDLE DATA,VOICE AND VEDIO AND PROVIDE MAXIMUM PERFORMANCE THROUGH PROPER PRIORITIZATION.
B)4096 IEEE 802.1Q (VLAN TAGGING)
C)THE CORE SWITCH SHOULD SUPPORT QUALITY OFSERVICE/CLASS OF SERVICE AS PER IEEE 802.1P STANDARD USING MULTIPLE PRIORITY QUEUES(MINIMUM 6 PRIORITY QUEUES)PER PORTS
LINK AGGREGATION...
THE CORE SWITCH SHOULD SUPPORT LINK AGGREGATION FOR HIGHER BANDWIDHTH,LINK REDUNDANCY ETC.AS PER THE IEEE 802.3AD STANDARD.
IEEE STANDARD SUPPORT....
A)THE CORE SWITCH SHOULD COMPLY WITH ALL RELEVANT IEEE STANDARDS SUCH AS IEEE 802.3Z (GIGABIT ETHERNET 1000BASE LX & SX)
B)IEEE 802.3AB (GIGABIT ETHERNET 1000BASET)
C)IEEE 802.3X (FLOW CONTROL)
D)IEEE 802.3AD LINK AGGREGATION
E)IEEE 802.3D SPANNING TREE
F)IEEE 802.1W RAPID RE-CONVERGENCE SPANING TREE
G)IEEE 802.3S FOR MULTIPLE SPANNING TREE
H)IEEE 802.3AE (10G ETHERNET)
MAC ADDRESS.....
MINIMUM 16000 ADDRESS LEARNING CAPACITY.
CLIENT AUTHENTICATION....
THE CORE SWITCH SHOULD SUPPORT SECURITY FETURES LIKE RADIUS AUTHENTICATION,802.1X ETC.
STROM CONTROL.....
BROADCAST,MULTICAST AND UNICAST STORM CONTROL FETURES
MULTICAST GROUP MANAGEMENT...
INTERNET GROUP MANAGEMENT PROTOCOL VERSION 1 & 2 &3 (PREFERRED) SUPPORT IGMP SNOPING
DHCP...
DHCP REPLAY TO FORWARD CLIENT REQUESTS TO DHCP SERVER
MANAGEMENT....
A)TELNET & SSH
B)WEB BASED,
C)THE CORE SWITCH SHOULD BE SNMP MANAGEABLE AS PER THE STANDARD RFC1157,SNMP V3 AND RMON-2 THE SNMP SOFTWARE SHOULD BE SUPPLIED WITH THE SWITCH FOR COMLETE MANAGEMENT COFIGURATION.
D)IT SHOULD BE POSSIBLE SET ANY PASSWORD FOR SNMP READ OR WRITE
ANALYZER PORT...
ANALYZER PORT CONFIGURATION FOR TRAFFIC MONITORING OF A SINGLE PORT ,A GROUP OF PORTS,OR ALL PORTS.
FORM FACTOR...
19" RACK MOUNTABLE.
ankbhasi Wed, 01/16/2008 - 02:24
  • Cisco Employee,
Hi Ramlal,
What you have posted are features and are not very much hardware dependent. Features are mostly software dependent and can be find in different feature set.
Cat6k is the top end model Cisco modular switch and will provide you most of the functionality you have posted. Cat4k also provide you basically most of the features you have posted depending on what hardware you have and if it supports le features.
Cat6k sup 720 with MSFC 3 will work nice and you can also go through the link I posted in my earlier post to find more details on hardware modules.
Ankur
