1310 with external antenna
andrew.brazier@... Mon, 01/21/2008 - 06:20
  • Bronze, 100 points or more
The other point to bear in mind is that although you can get a range of several kilometres with the right antenna, if you're using the 1310 as an AP, the client must have the range to reach back to the 1310 and the max range for most clients is about 200M in the open air.
