ips update server ip
Answered Question
Jan 16th, 2008
If i want to configure the IPS for auto update , it asked for update server ip address, what is this ip address? is this auto update configuration needed for signature update, or it is for other updates?
regards
Correct Answer by mhellman about 9 years 3 months ago
You can't point at the Cisco site, you need to host your own internal server for this purpose. Personally, I do not use or recommend putting version upgrades in this directory (I believe it will try to apply them if you do). We use the CLI for installing version upgrades. We use autoupdate for installing signature updates.
Overall Rating: 5 (1 ratings)
Correct Answer
mhellman Wed, 01/16/2008 - 07:19
  • Blue, 1500 points or more
alanajjar Thu, 01/17/2008 - 01:39
Thank you for your response, it was helpful. just for clarefication, to update ips signatures , you download the new update manually from cisco site to the update server. is this correct scenario?
with regards
mhellman Thu, 01/17/2008 - 06:17
that's correct. I believe you can fully automate with Cisco CSM product if that is your desire.
alanajjar Sun, 01/20/2008 - 01:29
Do you mean cisco CSM (Cisco Switching Module), because I check this, and I cant find support for signature update. are there any other means to make the signature update occure automatically. thanks again.
with regards
