01-16-2008 04:24 AM - edited 03-13-2019 04:52 PM
I've a question about busy trigger on lines belonging to a receptionist phone.
Sometimes when reception try to answer a call get the message "failed to MAKE a new call". I'm supposing it's a bug and I've opened a case BUT:
is there some "best practices" for configuring busy trigger on lines belonging to a ac phone ?
My receptionist has a 7960 and 5 lines; i'm still not sure if it's better to configure busy trigger at 1 or not. Now busy trigger is 2 for each line but if line 1 is busy, second call goes to line 2,
Luigi
01-16-2008 07:25 AM
Hi Luigi,
You are correct;
This is Bug CSCee40177
As far as the Busy Trigger Settings for AC Lines, I have never seen a "Best Practices" recommendation but most people use 1 and route on Busy to Lines 2-5 (in your case). This seems to be easier for the AC User to work with. Here is the one and only reference to AC Lines;
Based on the line settings on Directory Number Configuration window, Cisco CallManager Attendant Console can support multiple calls on a line. When no more outgoing calls can be made on a line, Cisco CallManager Attendant Console displays a warning message when the attendant attempts to make a call.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_1_3/ccmfeat/fsccmac.html#wp1145016
Hope this helps!
Rob
01-16-2008 08:20 AM
Hi Rob,
thanks for the reply. I've seen that bug, but I've the issue answering an incoming calls and not dialing.
It seems like, while I try to answer an incoming call, i put a call to the same number incoming ...
When You say "route on busy to line..." what do You mean ? I've read that is better not to use call-forwarding on ac controlled devices.
What I'm misunderstanding ?
Many thanks and regards
Luigi
01-16-2008 08:55 AM
Hi Luigi,
Sorry, I should have been more clear :( What I meant by "route on Busy" is just the use of the chosen Hunting Algorithym to search for the next available "non-busy" line on the device. The use of the Busy Trigger set at 1 will allow this Hunt to take place properly.
Does that make any more sense?
Hope this helps!
Rob
01-16-2008 10:37 AM
Hi Rob,
Yes, now I understood. I've configured the hunt-group as "route on first available line" but at this time operator lines has busy trigger configured at 3.
What I've seen is that also with busy trigger to 3, when a line is busy in a conversation, next call come on next line ( !? )
regards
Luigi
01-16-2008 06:25 PM
Hi Luigi,
I think you should try setting the Busy Trigger to 1. It may mitigate the problems you have encountered with the setting as 3.
Hope this helps!
Rob
